iPhone 11 Pro Max
Step 1 of 11
Press General.
Step 2 of 11
Press General.
Press Reset.
Step 3 of 11
Press Reset.
Press Reset All Settings.
Step 4 of 11
If you choose to restore settings only, all phone settings are restored but contacts, audio files, video clips and appointments will not be deleted.
Step 5 of 11
Press Reset All Settings. Wait a moment while the factory default settings are restored. Follow the instructions on the screen to set up your phone and prepare it for use.
Step 6 of 11
Press Erase All Content and Settings.
Step 7 of 11
If you choose to restore settings and data, settings, contacts, audio files, video clips and appointments are deleted. When you've restored settings and data, you need to activate your phone.
Press the required setting.
Step 8 of 11
Press Erase iPhone.
Step 9 of 11
Press Erase iPhone.
Press Erase iPhone.
Step 10 of 11
Press Erase iPhone.
Key in the password for your Apple ID and press Erase. Wait a moment while the factory default settings are restored. Follow the instructions on the screen to set up your phone and prepare it for use.
Step 11 of 11
x
Get information on
Or select
Another device
