iPhone 11 Pro Max
You can set up your phone to send and receive email messages from your email accounts. Using IMAP, your email messages are kept on the server and are synchronised between all of your devices. You're then able to access your email messages from other devices. To set up your phone for IMAP email, you need to set up your phone for internet.
Step 1 of 45
Press Mail.
Step 2 of 45
Press Mail.
Press Accounts.
Step 3 of 45
Press Accounts.
Press Add Account.
Step 4 of 45
Press Add Account.
Press Other.
Step 5 of 45
Press Other.
If the name of your email provider is on the list, press this instead.
Press Add Mail Account.
Step 6 of 45
Press Name and key in the required sender name.
Step 7 of 45
Press Email and key in your email address.
Step 8 of 45
Step 9 of 45
Press Description and key in the required name.
Step 10 of 45
Press Next.
Step 11 of 45
Press Next.
Step 12 of 45
Press IMAP.
Step 13 of 45
Press IMAP.
Press Host Name and key in the name of your email provider's incoming server.
Step 14 of 45
Press Username and key in the username for your email account.
Step 15 of 45
Press Host Name and key in the name of your email provider's outgoing server.
Step 16 of 45
Step 17 of 45
Step 18 of 45
Press Next.
Step 19 of 45
Press Next.
Press Save. Your email account has now been set up. To select more settings for incoming and outgoing server, proceed with the following steps.
Step 20 of 45
Press the name of the email account you've just set up.
Step 21 of 45
Press Account.
Step 22 of 45
Press Account.
Press SMTP.
Step 23 of 45
Press SMTP.
Press the field below
Step 24 of 45
Press the field below "PRIMARY SERVER".
Step 25 of 45
Press the indicator next to "Use SSL" to turn off the function.
Press Authentication.
Step 26 of 45
Press Password.
Step 27 of 45
Press Password.
Press arrow left.
Step 28 of 45
Press arrow left.
Press Server Port and key in 25.
25
Step 29 of 45
Press Done.
Step 30 of 45
Press Done.
Press arrow left.
Step 31 of 45
Press arrow left.
Press Advanced.
Step 32 of 45
Press Advanced.
Step 33 of 45
Step 34 of 45
Press Password.
Step 35 of 45
Press Password.
Press arrow left.
Step 36 of 45
Press arrow left.
Press Server Port and key in 143.
143
Step 37 of 45
Press arrow left.
Step 38 of 45
Press arrow left.
Press Done.
Step 39 of 45
Press Done.
Press arrow left.
Step 40 of 45
Press arrow left.
Press Fetch New Data.
Step 41 of 45
Step 42 of 45
Press the indicator next to "Push" to turn the function on or off.
If you turn off the function, press the required setting.
Step 43 of 45
Press the required email account and follow the instructions on the screen to select settings for the specific account.
Step 44 of 45
Step 45 of 45
x
Get information on
Or select
Another device
