iPhone 11 Pro Max
Selecting network mode
Press Mobile Data.
Press Mobile Data.
Press Mobile Data Options.
Press Voice & Data.
Press Voice & Data.
There may be different network modes available depending on where you are. If you set your phone to the fastest network mode, it will always find the network with the highest data speed and best signal.
Press the indicator next to "VoLTE" to turn the function on or off.
You can use 4G for voice calls via the mobile network for a faster and better connection. To turn VoLTE on or off, you need to select 4G (LTE) as network mode.
x
Get information on
Or select
Another device
