iPhone 11 Pro Max
Synchronising the phone contents using iCloud
You can synchronise the contents of your phone using iCloud enabling you to access the contents from different devices or restore them if you lose your phone. To use iCloud, you need to activate your Apple ID on your phone.
Step 1 of 9
Press your Apple ID.
Step 2 of 9
Press iCloud.
Step 3 of 9
Press iCloud.
Step 4 of 9
If you turn on file synchronisation, your files are automatically synchronised via Wi-Fi. You can synchronise the files on your phone, such as presentations, spreadsheets, PDF files and other kinds of documents with other devices using iCloud.
Press the indicator next to "iCloud Drive" to turn file synchronisation on or off.
Press Photos.
Step 5 of 9
Press Photos.
Step 6 of 9
Press the indicator next to "Upload to My Photo Stream" to turn the function on or off.
If you turn on the function, all new pictures on your phone are synchronised with other devices via iCloud.
Press arrow left.
Step 7 of 9
Press arrow left.
Press the indicators next to the required data types to turn synchronisation of each data type on or off.
Step 8 of 9
Step 9 of 9
x
Get information on
Or select
Another device
