iPhone 11 Pro Max
I can't check my voicemail
Solution 1 of 5: Your voicemail hasn't been turned on
To check your voice messages, you need to turn on your voicemail.
Send a text message with the text VM ON to 150 to turn on your voicemail.
x
Get information on
Or select
Another device
