iPhone 11 Pro Max
I can't make voice calls
Solution 7 of 8: Not adequate network coverage
The network coverage may differ from area to area. In certain areas it may so low that it's not possible to make calls.
Try making a call later when you're in an area with better network coverage. View our network coverage map.
