iPhone 11 Pro Max
iPhone 11 Pro Max
f-3a7e4ec0-1475-4f61-a930-084fea643e88
f-5a24cf43-c92b-4747-b090-cb49cce6a42d
f-f13b3424-3ff9-4db3-81c3-18e0f3392f93
f-ba1a3150-61a5-4025-8a07-71094920c51f
f-ac8ec1e2-754f-462d-b232-5b6f0225cf8f
f-a1614ec3-2011-49e3-9b5e-d8df99f321a8
Solution 3 of 14: Automatic app update is turned on
You can select whether your apps should be updated to the newest version automatically or manually. See how to install an app.
Step 1 of 5
Press App Store.
Press App Store.
Step 2 of 5
Press App Store.
Step 3 of 5
Press the indicator next to "App Updates" to turn the function on or off.
Step 4 of 5
Press the indicator next to "Automatic Downloads" to turn the function on or off.
Step 5 of 5
