iPhone 11 Pro Max
iPhone 11 Pro Max
f-3a7e4ec0-1475-4f61-a930-084fea643e88
f-5a24cf43-c92b-4747-b090-cb49cce6a42d
f-f13b3424-3ff9-4db3-81c3-18e0f3392f93
f-ba1a3150-61a5-4025-8a07-71094920c51f
f-ac8ec1e2-754f-462d-b232-5b6f0225cf8f
f-a1614ec3-2011-49e3-9b5e-d8df99f321a8
Personalising your phone's home screen
You can personalise the appearance of your phone's home screen, such as changing the size and colour of app icons and adding or removing home screen pages.
Press and hold anywhere on the home screen.
Step 1 of 17
Press Edit.
Press Edit.
Step 2 of 17
Press Edit.
Press Customise.
Press Customise.
Step 3 of 17
Press Customise.
Press the required setting to select the size of app icons on the home screen.
Step 4 of 17
Press the required setting to select background theme for the home screen.
Step 5 of 17
If you select Default, the background theme is automatically set to match your surroundings.
Step 6 of 17
If you select Tinted, follow the instructions on the screen to set the required colour theme for app icons on the home screen.
Step 7 of 17
Press and hold the required app icon. Drag the app icon to the required position on the home screen.
Step 8 of 17
Drag the app icon right or left to place the app icon on a new home screen page.
Step 9 of 17
Press Done.
Press Done.
Step 10 of 17
Press Done.
Step 11 of 17
Press Edit.
Press Edit.
Step 12 of 17
Press Edit.
Press Edit Pages.
Press Edit Pages.
Step 13 of 17
Press Edit Pages.
Press the field below the required home screen page to turn page view on or off.
Step 14 of 17
Press the delete icon next to the required home screen page.
Step 15 of 17
Press Remove.
Press Remove.
Step 16 of 17
Press Remove.
Press Done.
Press Done.
Step 17 of 17
Press Done.
