iPhone 12 Pro Max
I can't check my voicemail
Solution 5 of 5: You're trying to check your voice messages when abroad
The default voicemail number can only be used if you're calling form your home network.
Call +447953222222 to check your voice messages when abroad. Please note that you need to set a PIN before you can check your voice messages when abroad.
