iPhone 12 Pro Max
It's not possible to use my Visual Voicemail
Solution 1 of 8: There's an error in the operator settings on your phone
If you have problems using Visual Voicemail, you can try updating the operator settings on your phone.
Update the operator settings You can find the function by selecting "General" and then "About" in your phone's settings.
