iPhone 12 Pro Max
Solution 3 of 14: Automatic app update is turned on
You can select whether your apps should be updated to the newest version automatically or manually. See how to install an app.
Press App Store.
Press the indicator next to "App Updates" to turn the function on or off.
Press the indicator next to "Automatic Downloads" to turn the function on or off.
