iPhone 12 Pro Max
I can't use my phone as a personal hotspot
Solution 1 of 2: Personal hotspot isn't used correctly
When you use your phone as a personal hotspot, you can share your phone's internet connection with other devices via Wi-Fi. To use your phone as a personal hotspot, you need to set up your phone for internet.
Press Personal Hotspot.
Press Wi-Fi Password and key in the required password.
Press the confirm icon.
Press the indicator next to "Allow Others to Join" to turn on the function.
If Wi-Fi is turned off, press Turn on Wi-Fi and Bluetooth.
If Wi-Fi is turned on, press Wi-Fi and USB Only.
Find the list of available Wi-Fi networks and select the personal hotspot you've just set up.
Key in the password for the personal hotspot and establish the connection.
