iPhone 12 Pro Max
iPhone 12 Pro Max
f-d742ea13-14e2-474f-8382-3e0e7fe59842
f-0910fa10-f236-401c-9ed0-e129c3bd1bcf
f-47efced3-f74f-4ffa-bf14-c5ce5d5e5250
f-578d49fd-d837-4402-b763-2525e7f72184
f-20a530fb-49ae-4254-93f6-7da2dd35b37b
f-3c8a75dc-d3bf-413d-9a75-8f1944586cba
I can't use my phone as a personal hotspot
Solution 2 of 2: The password used on the other device is incorrect
To use your phone as a personal hotspot, you need to key in the password you selected when you set up your phone as a personal hotspot on the other device.
Check the password for the hotspot on your phone and key in the correct password on the other device.
