iPhone 12 Pro Max
iPhone 12 Pro Max
f-d742ea13-14e2-474f-8382-3e0e7fe59842
f-0910fa10-f236-401c-9ed0-e129c3bd1bcf
f-47efced3-f74f-4ffa-bf14-c5ce5d5e5250
f-578d49fd-d837-4402-b763-2525e7f72184
f-20a530fb-49ae-4254-93f6-7da2dd35b37b
f-3c8a75dc-d3bf-413d-9a75-8f1944586cba
Solution 3 of 14: Automatic app update is turned on
You can select whether your apps should be updated to the newest version automatically or manually. See how to install an app.
Step 1 of 6
Press Apps.
Press Apps.
Step 2 of 6
Press Apps.
Press App Store.
Press App Store.
Step 3 of 6
Press App Store.
Step 4 of 6
Press the indicator next to "App Updates" to turn the function on or off.
Step 5 of 6
Press the indicator next to "Automatic Downloads" to turn the function on or off.
Step 6 of 6
