iPhone 13 Pro Max
iPhone 13 Pro Max
f-fec54e55-142d-488a-8b4c-347e02a908dd
f-d78914dd-197a-4e96-aec0-b8f75edca070
f-44c6d572-3578-413b-aa98-ae277e5f67ec
f-91529581-c161-4c66-a67b-530cd5010dcb
f-9a6b9905-60b1-4280-be71-ea5fb192a512
f-66ee72a0-2250-4ecb-8b92-270710eb70d2
I can't use my phone as a personal hotspot
Solution 2 of 2: The password used on the other device is incorrect
To use your phone as a personal hotspot, you need to key in the password you selected when you set up your phone as a personal hotspot on the other device.
Check the password for the hotspot on your phone and key in the correct password on the other device.
