iPhone 14 Plus
It's not possible to use my Visual Voicemail
Solution 4 of 8: Visual Voicemail isn't included in your price plan
To use Visual Voicemail, Visual Voicemail needs to be included in your price plan.
You can't use Visual Voicemail if you're on a Pay as you go or Flex plan.
