iPhone 14 Plus
Using Face ID
You can set your phone to use face recognition as phone lock code or to authorise iTunes and App Store purchases.
Press Face ID & Passcode.
Press Set Up Face ID.
Press Get Started and follow the instructions on the screen to set up Face ID.
Press Set Up Later.
Press Done. If you haven't previously selected a phone lock code, key in a code of your own choice twice.
