iPhone 14 Pro
iPhone 14 Pro
f-67c74171-16f4-48bc-9421-d5b5bb5d6e56
f-2b2c212a-f656-4d47-8bb5-a8239451f2e8
f-2804f4e7-bd47-430b-a54e-9fc378e52b12
f-90eb9658-9ed7-4199-8602-3a8b37252d43
f-de751853-aa46-4dce-8e44-e187710f2833
f-d6defceb-e468-4ec6-9fc3-d4ce7dd2e0d3
f-83f16e6f-b753-46a7-a441-969b3d29192e
It's not possible to use my Visual Voicemail
Solution 5 of 8: Your Visual Voicemail hasn't been turned on
Using Visual Voicemail, you can see a list of the messages you've received on your voicemail, play them back or delete them. You can also record a personal greeting or select a default greeting.
Apple iPhone 14 Pro
Apple iPhone 14 Pro
Step 1 of 1
Send a text message with the text IPHONE VISUAL to 150. You will receive a text message from us when your Visual Voicemail has been turned on.
