iPhone 14 Pro Max
![f-c5d651ba-f8b1-4091-9266-a4caa24fb8dd](http://wmstatic.global.ssl.fastly.net/ml/120824-f-c5d651ba-f8b1-4091-9266-a4caa24fb8dd.png?width=140&height=200)
![f-2c7d559d-d19a-48bd-a4b1-94362d8db40f](http://wmstatic.global.ssl.fastly.net/ml/120824-f-2c7d559d-d19a-48bd-a4b1-94362d8db40f.png?width=140&height=200)
![f-9b1bcdb5-8031-4c85-96e3-f2ce67a159a8](http://wmstatic.global.ssl.fastly.net/ml/120824-f-9b1bcdb5-8031-4c85-96e3-f2ce67a159a8.png?width=140&height=200)
![f-08f52ffe-e04d-4146-a24b-d48183d0a01c](http://wmstatic.global.ssl.fastly.net/ml/120824-f-08f52ffe-e04d-4146-a24b-d48183d0a01c.png?width=140&height=200)
![f-d2481693-78e0-4d38-89b8-2c909adf0208](http://wmstatic.global.ssl.fastly.net/ml/120824-f-d2481693-78e0-4d38-89b8-2c909adf0208.png?width=140&height=200)
![f-2ad5327e-1948-4825-95d0-43251d27829b](http://wmstatic.global.ssl.fastly.net/ml/120824-f-2ad5327e-1948-4825-95d0-43251d27829b.png?width=140&height=200)
Using your phone as a personal hotspot
When you use your phone as a personal hotspot, you can share your phone's internet connection with other devices via Wi-Fi. To use your phone as a personal hotspot, you need to set up your phone for internet.
![Press Settings. Press Settings.](http://wmstatic.global.ssl.fastly.net/ml/120824-f-2ff25a93-a310-4d1a-9ef4-0dc13817d784.png?width=238&height=514)
![Press Settings. Press Settings.](http://wmstatic.global.ssl.fastly.net/ml/120824-f-2ff25a93-a310-4d1a-9ef4-0dc13817d784.png?width=354&height=766)
![Press Personal Hotspot. Press Personal Hotspot.](http://wmstatic.global.ssl.fastly.net/ml/120824-f-b0941495-b23e-4cb1-8b0a-743db95a32d6.png?width=238&height=514)
![Press Personal Hotspot. Press Personal Hotspot.](http://wmstatic.global.ssl.fastly.net/ml/120824-f-b0941495-b23e-4cb1-8b0a-743db95a32d6.png?width=354&height=766)
![Press Wi-Fi Password and key in the required password. Press Wi-Fi Password and key in the required password.](http://wmstatic.global.ssl.fastly.net/ml/120824-f-13328fe4-c913-4ebe-bd06-e271bbfa1d4e.png?width=238&height=514)
![Press Wi-Fi Password and key in the required password. Press Wi-Fi Password and key in the required password.](http://wmstatic.global.ssl.fastly.net/ml/120824-f-13328fe4-c913-4ebe-bd06-e271bbfa1d4e.png?width=354&height=766)
![Press Done. Press Done.](http://wmstatic.global.ssl.fastly.net/ml/120824-f-93e508d0-0b63-4054-b8fe-1480491864df.png?width=238&height=514)
![Press Done. Press Done.](http://wmstatic.global.ssl.fastly.net/ml/120824-f-93e508d0-0b63-4054-b8fe-1480491864df.png?width=354&height=766)
Press Done.
![Press the indicator next to Press the indicator next to](http://wmstatic.global.ssl.fastly.net/ml/120824-f-13328fe4-c913-4ebe-bd06-e271bbfa1d4e.png?width=238&height=514)
![Press the indicator next to Press the indicator next to](http://wmstatic.global.ssl.fastly.net/ml/120824-f-13328fe4-c913-4ebe-bd06-e271bbfa1d4e.png?width=354&height=766)
Press the indicator next to "Allow Others to Join" to turn on the function.
![If Wi-Fi is turned off, press Turn on Wi-Fi and Bluetooth. If Wi-Fi is turned off, press Turn on Wi-Fi and Bluetooth.](http://wmstatic.global.ssl.fastly.net/ml/120824-f-507a54da-13c2-4d6a-bf4c-f3a56260e13e.png?width=238&height=514)
![If Wi-Fi is turned off, press Turn on Wi-Fi and Bluetooth. If Wi-Fi is turned off, press Turn on Wi-Fi and Bluetooth.](http://wmstatic.global.ssl.fastly.net/ml/120824-f-507a54da-13c2-4d6a-bf4c-f3a56260e13e.png?width=354&height=766)
![If Wi-Fi is turned on, press Wi-Fi and USB Only. If Wi-Fi is turned on, press Wi-Fi and USB Only.](http://wmstatic.global.ssl.fastly.net/ml/120824-f-f53ac4d0-0f13-414b-afb2-cbac8781c134.png?width=238&height=514)
![If Wi-Fi is turned on, press Wi-Fi and USB Only. If Wi-Fi is turned on, press Wi-Fi and USB Only.](http://wmstatic.global.ssl.fastly.net/ml/120824-f-f53ac4d0-0f13-414b-afb2-cbac8781c134.png?width=354&height=766)
![Slide your finger upwards starting from the bottom of the screen to return to the home screen. Slide your finger upwards starting from the bottom of the screen to return to the home screen.](http://wmstatic.global.ssl.fastly.net/ml/120824-f-126663ec-4835-4c24-9d3c-b7b4433a39ff.png?width=238&height=514)
![Slide your finger upwards starting from the bottom of the screen to return to the home screen. Slide your finger upwards starting from the bottom of the screen to return to the home screen.](http://wmstatic.global.ssl.fastly.net/ml/120824-f-126663ec-4835-4c24-9d3c-b7b4433a39ff.png?width=354&height=766)
![Apple iPhone 14 Pro Max Apple iPhone 14 Pro Max](http://wmstatic.global.ssl.fastly.net/ml/120824-f-846ac051-0687-450b-ba32-48c135099892.png?width=520&height=540)
![Apple iPhone 14 Pro Max Apple iPhone 14 Pro Max](http://wmstatic.global.ssl.fastly.net/ml/120824-f-846ac051-0687-450b-ba32-48c135099892.png?width=540&height=800)
Find the list of available Wi-Fi networks and select the personal hotspot you've just set up.
Key in the password for the personal hotspot and establish the connection.
