iPhone 14 Pro Max
Using music player
You can use the music player to play audio files you have transferred to your phone.
Press the music player icon.
Press Playlists.
Press the new playlist icon.
Press the text input field and key in a name for the playlist.
Press Create.
Press Add Music.
Go to the required category and press the add icon next to the required audio file.
Press Done.
Go to the required category or playlist and press the required audio file.
Press the Volume keys to select volume.
Press the song title.
Press arrow right to go to the next audio file.
Press arrow left twice to go to previous audio file.
Press the playback queue icon.
Press the shuffle icon to turn the function on or off.
Press the repeat icon to turn the function on or off.
