iPhone 14 Pro Max
iPhone 14 Pro Max
f-d56c5cc8-2a6c-4b37-8a27-9bd0f1fcc52f
f-2c7d559d-d19a-48bd-a4b1-94362d8db40f
f-9b1bcdb5-8031-4c85-96e3-f2ce67a159a8
f-08f52ffe-e04d-4146-a24b-d48183d0a01c
f-d2481693-78e0-4d38-89b8-2c909adf0208
f-2ad5327e-1948-4825-95d0-43251d27829b
f-901232d2-4559-4115-918f-66fef8697af0
I can't use my phone as a personal hotspot
Solution 1 of 2: Personal hotspot isn't used correctly
When you use your phone as a personal hotspot, you can share your phone's internet connection with other devices via Wi-Fi. To use your phone as a personal hotspot, you need to set up your phone for internet.
Step 1 of 12
Press Personal Hotspot.
Step 2 of 12
Press Wi-Fi Password and key in the required password.
Step 3 of 12
Press the confirm icon.
Step 4 of 12
Step 5 of 12
Press the indicator next to "Allow Others to Join" to turn on the function.
If Wi-Fi is turned off, press Turn on Wi-Fi and Bluetooth.
Step 6 of 12
If Wi-Fi is turned on, press Wi-Fi and USB Only.
Step 7 of 12
Step 8 of 12
Apple iPhone 14 Pro Max
Step 9 of 12
Step 10 of 12
Find the list of available Wi-Fi networks and select the personal hotspot you've just set up.
Step 11 of 12
Key in the password for the personal hotspot and establish the connection.
Step 12 of 12
