iPhone 15 Plus
iPhone 15 Plus
f-15e51018-41ab-44b6-a301-e42d69c35cf7
f-55f5d531-b5a7-4eb6-98b2-38af82756c03
f-614f8a17-4060-4d02-b0df-f2563eeb50f0
f-b8ce3d19-43bd-4226-bfce-32b61f566c20
f-59725835-67de-4ecd-ac38-0f3ec9505cc8
f-5de60efa-0c90-43ba-8696-6ed22f688131
It's not possible to use my Visual Voicemail
Solution 1 of 8: Your Visual Voicemail hasn't been turned on
Using Visual Voicemail, you can see a list of the messages you've received on your voicemail, play them back or delete them. You can also record a personal greeting or select a default greeting.
Apple iPhone 15 Plus
Step 1 of 1
Send a text message with the text IPHONE VISUAL to 150. You will receive a text message from us when your Visual Voicemail has been turned on.
