iPhone 15 Pro Max
iPhone 15 Pro Max
f-3815ee15-2f4d-49e9-afa4-e905a187481a
f-d77755cb-0353-4e8e-bb39-0cf6df40fced
f-324b9c27-0f88-46a4-90d8-d85989eb1ead
f-90385a7b-9fe9-4bde-beec-f4b6ee87d86d
f-b62c8a9b-0d1e-4cb3-8120-8b08a3f99570
f-f6d8b25e-c1e0-421e-8286-b114093e19a3
Device home
Getting started
Basic functions
Calls, contacts, messaging
Selecting lock screen settings
You can set several lock screens on your phone and select different settings for them, such as background image, widgets and focus mode.
Press and hold anywhere on the lock screen.
Step 1 of 31
Press the add icon.
Press the add icon.
Step 2 of 31
Press the add icon.
Press the required category and follow the instructions on the screen to select the required background image.
Step 3 of 31
Depending on your choice, you can adjust the appearance of your lock screen background, e.g. by selecting colour filter and depth effect.
To customise the way the lock screen date is displayed, press the date widget and follow the instructions on the screen to find the required widget display mode.
Step 4 of 31
To customise the way the lock screen time is displayed, press the clock widget and follow the instructions on the screen to select the required settings.
Step 5 of 31
To add more lock screen widgets, press the widget field and follow the instructions on the screen to select the required widgets.
Step 6 of 31
Press Add.
Press Add.
Step 7 of 31
Press Add.
To use the same colour theme on the home screen, press Set as Wallpaper Pair.
Step 8 of 31
To use a different look for the home screen, press Customise Home Screen and follow the instructions on the screen to select the required settings.
Step 9 of 31
Press Focus.
Press Focus.
Step 10 of 31
Press Focus.
Press the required focus mode.
Step 11 of 31
You can set your phone to use a specific lock screen with a specific focus mode. See how to select focus mode settings.
Press the close icon.
Step 12 of 31
Slide your finger upwards starting from the bottom of the screen when you're done.
Step 13 of 31
Step 14 of 31
Slide your finger right or left on the screen to select the required lock screen.
Step 15 of 31
Press the required lock screen.
Step 16 of 31
Step 17 of 31
Step 18 of 31
Press Customise and follow the instructions on the screen to customise the selected lock screen.
Step 19 of 31
Step 20 of 31
Step 21 of 31
Slide your finger upwards on the required lock screen.
Step 22 of 31
Press the delete icon.
Step 23 of 31
Press Delete This Wallpaper.
Step 24 of 31
Step 25 of 31
Step 26 of 31
Press Display & Brightness.
Step 27 of 31
Press Always On Display.
Step 28 of 31
Step 29 of 31
Press the indicator next to "Always On Display" to turn the function on or off.
You can dim the lock screen on your phone and still have all your content displayed, e.g. background image, clock and widgets.
If you turn on the function, press the indicators next to the required settings to turn them on or off.
Step 30 of 31
Step 31 of 31
