iPhone 15 Pro Max
iPhone 15 Pro Max
f-3815ee15-2f4d-49e9-afa4-e905a187481a
f-d77755cb-0353-4e8e-bb39-0cf6df40fced
f-324b9c27-0f88-46a4-90d8-d85989eb1ead
f-90385a7b-9fe9-4bde-beec-f4b6ee87d86d
f-b62c8a9b-0d1e-4cb3-8120-8b08a3f99570
f-f6d8b25e-c1e0-421e-8286-b114093e19a3
I can't use my phone as a personal hotspot
Solution 2 of 2: The password used on the other device is incorrect
To use your phone as a personal hotspot, you need to key in the password you selected when you set up your phone as a personal hotspot on the other device.
Check the password for the hotspot on your phone and key in the correct password on the other device.
