iPhone 15 Pro Max
iPhone 15 Pro Max
f-3815ee15-2f4d-49e9-afa4-e905a187481a
f-d77755cb-0353-4e8e-bb39-0cf6df40fced
f-324b9c27-0f88-46a4-90d8-d85989eb1ead
f-90385a7b-9fe9-4bde-beec-f4b6ee87d86d
f-b62c8a9b-0d1e-4cb3-8120-8b08a3f99570
f-f6d8b25e-c1e0-421e-8286-b114093e19a3
Extending the battery life
Step 1 of 6
Press Battery.
Press Battery.
Step 2 of 6
Press Battery.
Press Power Mode.
Press Power Mode.
Step 3 of 6
Press Power Mode.
Step 4 of 6
Press the indicator next to "Adaptive Power" to turn on the function.
When Adaptive Power is turned on, Apple Intelligence is used to detect when your phone is using more power than usual, and automatically makes small adjustments to things like brightness and background apps so that your phone holds its charge for longer. To use the function, you need to turn on Apple Intelligence.
Step 5 of 6
Press the indicator next to "Low Power Mode" to turn on the function.
Step 6 of 6
