iPhone 15 Pro Max
iPhone 15 Pro Max
f-3815ee15-2f4d-49e9-afa4-e905a187481a
f-d77755cb-0353-4e8e-bb39-0cf6df40fced
f-324b9c27-0f88-46a4-90d8-d85989eb1ead
f-90385a7b-9fe9-4bde-beec-f4b6ee87d86d
f-b62c8a9b-0d1e-4cb3-8120-8b08a3f99570
f-f6d8b25e-c1e0-421e-8286-b114093e19a3
Solution 3 of 14: Automatic app update is turned on
You can select whether your apps should be updated to the newest version automatically or manually. See how to install an app.
Step 1 of 6
Press Apps.
Press Apps.
Step 2 of 6
Press Apps.
Press App Store.
Press App Store.
Step 3 of 6
Press App Store.
Step 4 of 6
Press the indicator next to "App Updates" to turn the function on or off.
Step 5 of 6
Press the indicator next to "Automatic Downloads" to turn the function on or off.
Step 6 of 6
