iPhone 15 Pro Max
Selecting settings for Siri AI
You can use Siri AI to answer your questions in an informative way, perform tasks and interact with apps on your phone. To use Siri AI, you need to activate your Apple Account on your phone.
Press Siri.
If it's the first time you use Siri AI, press Turn On Siri.
Press Try Siri AI and follow the instructions on the screen to turn on the function.
Press Requests.
Press the required setting to turn the function on or off. If you turn on the function, you need to follow the instructions on the screen to set up Siri to recognise your voice.
Press the indicator next to "Press Side Button for Siri" to turn activation using the Side button on or off.
Press arrow left.
Press Language and follow the instructions on the screen to select the required language.
Press Voice and follow the instructions on the screen to select the required accent and voice.
Press Responses and follow the instructions on the screen to select the required settings.
Press Your Information.
Press the required contact.
Press the required category below "Siri App" and follow the instructions on the screen to select the required settings.
Press ChatGPT and follow the instructions on the screen to turn use of ChatGPT on or off.
Follow the instructions on the screen to select more settings for Siri AI.
