iPhone 16 Pro
iPhone 16 Pro
f-07006e2f-0bd8-404b-9015-3ab5fe403b73
f-a8d7d30c-8288-4714-9e92-f375e840734d
f-870bd54c-38eb-4a24-9f7b-de420d0ade5b
f-e3db2525-ba6e-4947-bb6d-4c7e0937fb93
f-271e17b9-43ff-427a-abaa-90402e32ca6d
f-858b25ed-3f6e-463b-8187-8529101507e6
f-4132fcac-0340-4581-9905-fa17ef50280f
f-0958befa-6b51-4b4a-9669-0e785c6232f8
It's not possible to use my Visual Voicemail
Solution 5 of 8: Your Visual Voicemail hasn't been turned on
Using Visual Voicemail, you can see a list of the messages you've received on your voicemail, play them back or delete them. You can also record a personal greeting or select a default greeting.
Apple iPhone 16 Pro
Apple iPhone 16 Pro
Step 1 of 1
Send a text message with the text IPHONE VISUAL to 150. You will receive a text message from us when your Visual Voicemail has been turned on.
