iPhone 16 Pro Max
iPhone 16 Pro Max
f-bd356d62-013e-43d4-8cfc-02ea1e36deb2
f-4a8a5595-783b-4e0e-8467-d2d5e9fc4016
f-388ab6ae-eae7-4ecc-8984-b40574146c13
f-a3ca6912-9c27-4750-ad0e-6d2b17b1d94b
f-f1ab022a-d37e-47a9-85ba-49e9e77fcbc8
f-39a9b493-0785-4d9a-9273-0cebbabc19f7
f-aaf55971-cf99-4796-b86c-19cddc9f018a
f-e8815344-f66c-445a-9932-f831589ad59e
Device home
Getting started
Basic functions
Calls, contacts, messaging
Turning on Visual Voicemail
Using Visual Voicemail, you can see a list of the messages you've received on your voicemail, play them back or delete them. You can also record a personal greeting or select a default greeting.
Apple iPhone 16 Pro Max
Step 1 of 1
Send a text message with the text IPHONE VISUAL to 150. You will receive a text message from us when your Visual Voicemail has been turned on.
