iPhone 16 Pro Max
iPhone 16 Pro Max
f-4e9b6905-6707-4dee-bfec-c993e12cfb6e
f-4a8a5595-783b-4e0e-8467-d2d5e9fc4016
f-388ab6ae-eae7-4ecc-8984-b40574146c13
f-a3ca6912-9c27-4750-ad0e-6d2b17b1d94b
f-f1ab022a-d37e-47a9-85ba-49e9e77fcbc8
f-39a9b493-0785-4d9a-9273-0cebbabc19f7
f-aaf55971-cf99-4796-b86c-19cddc9f018a
f-e8815344-f66c-445a-9932-f831589ad59e
It's not possible to use my Visual Voicemail
Solution 6 of 8: Visual Voicemail isn't used correctly
Using Visual Voicemail, you can see a list of the messages you've received on your voicemail, play them back or delete them. You can also record a personal greeting or select a default greeting. To use Visual Voicemail, you need to turn on Visual Voicemail.
Press the phone icon.
Step 1 of 19
Step 2 of 19
Press Voicemail.
Press Voicemail.
Step 3 of 19
Press Voicemail.
Press Edit.
Press Edit.
Step 4 of 19
Press Edit.
Press Edit Voicemail Greeting.
Step 5 of 19
Press Default to select the default greeting.
Step 6 of 19
Press Custom to select a personal greeting.
Step 7 of 19
Press Record to start recording a personal greeting.
Step 8 of 19
Press Stop to stop recording.
Step 9 of 19
Press the play icon to play your personal greeting.
Step 10 of 19
Press the confirm icon.
Step 11 of 19
Press the required message.
Step 12 of 19
Press the play icon.
Step 13 of 19
Press the speaker icon to turn the speaker on or off.
Step 14 of 19
Press the call icon to call the sender.
Step 15 of 19
Press the share icon.
Step 16 of 19
Press the required setting and follow the instructions on the screen to share or save the message.
Step 17 of 19
Press the delete icon.
Step 18 of 19
Step 19 of 19
