iPhone 16 Pro Max
iPhone 16 Pro Max
f-4e9b6905-6707-4dee-bfec-c993e12cfb6e
f-4a8a5595-783b-4e0e-8467-d2d5e9fc4016
f-388ab6ae-eae7-4ecc-8984-b40574146c13
f-a3ca6912-9c27-4750-ad0e-6d2b17b1d94b
f-f1ab022a-d37e-47a9-85ba-49e9e77fcbc8
f-39a9b493-0785-4d9a-9273-0cebbabc19f7
f-aaf55971-cf99-4796-b86c-19cddc9f018a
f-e8815344-f66c-445a-9932-f831589ad59e
I can't use my phone as a personal hotspot
Solution 2 of 2: The password used on the other device is incorrect
To use your phone as a personal hotspot, you need to key in the password you selected when you set up your phone as a personal hotspot on the other device.
Check the password for the hotspot on your phone and key in the correct password on the other device.
