iPhone 16 Pro Max
iPhone 16 Pro Max
f-4e9b6905-6707-4dee-bfec-c993e12cfb6e
f-4a8a5595-783b-4e0e-8467-d2d5e9fc4016
f-388ab6ae-eae7-4ecc-8984-b40574146c13
f-a3ca6912-9c27-4750-ad0e-6d2b17b1d94b
f-f1ab022a-d37e-47a9-85ba-49e9e77fcbc8
f-39a9b493-0785-4d9a-9273-0cebbabc19f7
f-aaf55971-cf99-4796-b86c-19cddc9f018a
f-e8815344-f66c-445a-9932-f831589ad59e
Backing up phone memory to iCloud
You can back up the phone memory to iCloud to ensure that no data is lost when you update your phone's software or if you lose your phone. To back up the phone memory to iCloud, you need to activate your Apple Account on your phone and establish a connection to a Wi-Fi network.
Press your Apple Account.
Press iCloud.
Press iCloud.
Press iCloud.
Press iCloud Backup.
Press the indicator next to "Back Up This iPhone" to turn on the function.
The phone memory will be backed up automatically when your phone is charging, the screen lock is turned on and a Wi-Fi connection is established.
Press the indicator next to "Back Up Over Mobile Data" to turn the function on or off.
The phone memory will be backed up automatically using the mobile network when no Wi-Fi networks are within range.
Press Back Up Now and wait while the phone memory is backed up.
