iPhone 16 Pro Max
iPhone 16 Pro Max
f-4e9b6905-6707-4dee-bfec-c993e12cfb6e
f-4a8a5595-783b-4e0e-8467-d2d5e9fc4016
f-388ab6ae-eae7-4ecc-8984-b40574146c13
f-a3ca6912-9c27-4750-ad0e-6d2b17b1d94b
f-f1ab022a-d37e-47a9-85ba-49e9e77fcbc8
f-39a9b493-0785-4d9a-9273-0cebbabc19f7
f-aaf55971-cf99-4796-b86c-19cddc9f018a
f-e8815344-f66c-445a-9932-f831589ad59e
Solution 3 of 7: Notifications are turned on
You can set your phone to display notifications about missed calls, new messages and appointments in the status bar at the top of the screen.
Step 1 of 33
Press Notifications.
Step 2 of 33
Press Scheduled Summary.
Step 3 of 33
Step 4 of 33
Press the indicator next to "Scheduled Summary" to turn on the function and follow the instructions on the screen to set the notification summary.
Press arrow left.
Press arrow left.
Step 5 of 33
Press arrow left.
Press Show Previews.
Step 6 of 33
To select notification preview on the lock screen, press Always.
Step 7 of 33
To select notification preview only when your phone is unlocked, press When Unlocked.
Step 8 of 33
To turn off notification preview, press Never.
Step 9 of 33
Press arrow left.
Press arrow left.
Step 10 of 33
Press arrow left.
Press Screen Sharing.
Step 11 of 33
Step 12 of 33
Press the indicator next to "Allow Notifications" to turn the function on or off.
Press arrow left.
Press arrow left.
Step 13 of 33
Press arrow left.
Press Prioritise Notifications.
Step 14 of 33
Step 15 of 33
Press the indicator next to "Prioritise Notifications" to turn the function on or off.
If you turn on the function, follow the instructions on the screen to select more settings.
Step 16 of 33
Press arrow left.
Press arrow left.
Step 17 of 33
Press arrow left.
Press Summarise Notifications.
Step 18 of 33
Step 19 of 33
Press the indicator next to "Summarise Notifications" to turn the function on or off.
Step 20 of 33
Press arrow left.
Press arrow left.
Step 21 of 33
Press arrow left.
Press Suggestion Notifications.
Step 22 of 33
Step 23 of 33
Press the indicators next to the required applications to turn Siri suggestions for each application on or off.
Step 24 of 33
Press the required application.
Step 25 of 33
Step 26 of 33
Press the indicator next to "Allow Notifications" to turn notifications for the selected application on or off.
Press Notification Grouping.
Step 27 of 33
Press the required setting.
Step 28 of 33
Press arrow left.
Press arrow left.
Step 29 of 33
Press arrow left.
Step 30 of 33
Step 31 of 33
Press the required notification and follow the instructions on the screen to use the selected function.
Step 32 of 33
Step 33 of 33
