iPhone 17 Pro Max
iPhone 17 Pro Max
f-dde64d30-5b33-4c27-bedc-89ba8d9598b5
f-42923b7e-de72-4553-8f98-7e4a8c4e2a4b
f-a77ac41e-fe86-4587-b93e-3e9515c882b0
f-331b6aa1-ac05-44d2-9281-41d805a40128
f-311907a0-c0c8-4d82-bfbc-57963d1f8a19
f-62e62e7f-7d04-4248-9de4-e62cc909780a
f-8ff3c0e2-d79a-4838-af6d-e55e0ea11f2a
f-1d90912e-b192-48b2-89a5-401bab10a36d
Using notifications
You can set your phone to display notifications about missed calls, new messages and appointments in the status bar at the top of the screen.
Step 1 of 30
Press Notifications.
Step 2 of 30
Press Scheduled Summary.
Step 3 of 30
Step 4 of 30
Press the indicator next to "Scheduled Summary" to turn on the function and follow the instructions on the screen to set the notification summary.
You can set your phone to give you a personalised notification summary at a time of your choosing.
Press arrow left.
Press arrow left.
Step 5 of 30
Press arrow left.
Press Show Previews.
Step 6 of 30
To select notification preview on the lock screen, press Always.
Step 7 of 30
To select notification preview only when your phone is unlocked, press When Unlocked.
Step 8 of 30
To turn off notification preview, press Never.
Step 9 of 30
Press arrow left.
Press arrow left.
Step 10 of 30
Press arrow left.
Press Screen Sharing.
Step 11 of 30
Step 12 of 30
Press the indicator next to "Allow Notifications" to turn the function on or off.
You can turn display of notifications when using SharePlay or Screen Mirroring on or off.
Press arrow left.
Press arrow left.
Step 13 of 30
Press arrow left.
Press Prioritise Notifications.
Step 14 of 30
You can use Apple Intelligence to prioritise important and time-sensitive notifications. High priority notifications appear at the top of the notification list. To use the function, you need to turn on Apple Intelligence.
Step 15 of 30
Press the indicator next to "Prioritise Notifications" to turn the function on or off.
If you turn on the function, follow the instructions on the screen to select more settings.
Step 16 of 30
Press arrow left.
Press arrow left.
Step 17 of 30
Press arrow left.
Press Summarise Notifications.
Step 18 of 30
You can use Apple Intelligence to summarise notifications so you can quickly see the information that is most important to you. To use the function, you need to turn on Apple Intelligence.
Step 19 of 30
Press the indicator next to "Summarise Notifications" to turn the function on or off.
Step 20 of 30
Press arrow left.
Press arrow left.
Step 21 of 30
Press arrow left.
Press the required application.
Step 22 of 30
Step 23 of 30
Press the indicator next to "Allow Notifications" to turn notifications for the selected application on or off.
Press Notification Grouping.
Step 24 of 30
This function enables you to select whether notifications should be grouped or be displayed individually.
Press the required setting.
Step 25 of 30
Press arrow left.
Press arrow left.
Step 26 of 30
Press arrow left.
Step 27 of 30
Step 28 of 30
Press the required notification and follow the instructions on the screen to use the selected function.
Step 29 of 30
Step 30 of 30
