iPhone 17 Pro Max
iPhone 17 Pro Max
f-dde64d30-5b33-4c27-bedc-89ba8d9598b5
f-42923b7e-de72-4553-8f98-7e4a8c4e2a4b
f-a77ac41e-fe86-4587-b93e-3e9515c882b0
f-331b6aa1-ac05-44d2-9281-41d805a40128
f-311907a0-c0c8-4d82-bfbc-57963d1f8a19
f-62e62e7f-7d04-4248-9de4-e62cc909780a
f-8ff3c0e2-d79a-4838-af6d-e55e0ea11f2a
f-1d90912e-b192-48b2-89a5-401bab10a36d
I can't use my phone as a personal hotspot
Solution 1 of 2: Personal hotspot isn't used correctly
When you use your phone as a personal hotspot, you can share your phone's internet connection with other devices via Wi-Fi. To use your phone as a personal hotspot, you need to set up your phone for internet.
Step 1 of 12
Press Personal Hotspot.
Step 2 of 12
Press Wi-Fi Password and key in the required password.
Step 3 of 12
Press the confirm icon.
Step 4 of 12
Step 5 of 12
Press the indicator next to "Allow Others to Join" to turn on the function.
If Wi-Fi is turned off, press Turn on Wi-Fi and Bluetooth.
Step 6 of 12
If Wi-Fi is turned on, press Wi-Fi and USB Only.
Step 7 of 12
Step 8 of 12
Apple iPhone 17 Pro Max
Step 9 of 12
Step 10 of 12
Find the list of available Wi-Fi networks and select the personal hotspot you've just set up.
Step 11 of 12
Key in the password for the personal hotspot and establish the connection.
Step 12 of 12
