iPhone 17 Pro Max
Solution 12 of 14: Notifications are turned on
You can set your phone to display notifications about missed calls, new messages and appointments in the status bar at the top of the screen.
Press Notifications.
Press Scheduled Summary.
Press the indicator next to "Scheduled Summary" to turn on the function and follow the instructions on the screen to set the notification summary.
Press arrow left.
Press Show Previews.
To select notification preview on the lock screen, press Always.
To select notification preview only when your phone is unlocked, press When Unlocked.
To turn off notification preview, press Never.
Press arrow left.
Press Screen Sharing.
Press the indicator next to "Allow Notifications" to turn the function on or off.
Press arrow left.
Press Prioritise Notifications.
Press the indicator next to "Prioritise Notifications" to turn the function on or off.
If you turn on the function, follow the instructions on the screen to select more settings.
Press arrow left.
Press Summarise Notifications.
Press the indicator next to "Summarise Notifications" to turn the function on or off.
Press arrow left.
Press the required application.
Press the indicator next to "Allow Notifications" to turn notifications for the selected application on or off.
Press Notification Grouping.
Press the required setting.
Press arrow left.
Press the required notification and follow the instructions on the screen to use the selected function.
