iPhone 17 Pro Max
iPhone 17 Pro Max
f-dde64d30-5b33-4c27-bedc-89ba8d9598b5
f-42923b7e-de72-4553-8f98-7e4a8c4e2a4b
f-a77ac41e-fe86-4587-b93e-3e9515c882b0
f-331b6aa1-ac05-44d2-9281-41d805a40128
f-311907a0-c0c8-4d82-bfbc-57963d1f8a19
f-62e62e7f-7d04-4248-9de4-e62cc909780a
f-8ff3c0e2-d79a-4838-af6d-e55e0ea11f2a
f-1d90912e-b192-48b2-89a5-401bab10a36d
Solution 2 of 7: Automatic mobile data usage is turned on
You can set your phone to use mobile data automatically when the connection to the Wi-Fi network is weak. To turn Wi-Fi Assist on or off, you need to turn on mobile data.
Step 1 of 4
Press Wi-Fi.
Press Wi-Fi.
Step 2 of 4
Press Wi-Fi.
Step 3 of 4
Press the indicator next to "Connectivity Assist" to turn the function on or off.
Step 4 of 4
