Watch Series 10
Apple Watch Series 10
f-97e65d25-4966-4b82-93b8-ef302d1dbb5a
f-1cadca11-b442-4f63-aea0-686ebb8e4200
f-7d564155-d586-44f5-86c6-5fb4e0454fcd
f-d82b6dd3-9776-4aca-b0c8-b4ac188f8bab
f-96b4d8b6-5304-4cf3-81aa-6f5584e939c3
f-0f7fbe03-d948-4e20-85a3-252f839e23bd
f-a698d9a8-64d7-4df2-b966-0e5c0d229fa0
No ring tone is heard on incoming calls
Solution 3 of 3: Cinema Mode is turned on
With theater mode turned on, the screen on your Apple Watch will not light up when you raise your arm or when you receive messages, calls and notifications. At the same time, your Apple Watch will be set to silent mode.
Press the Side button.
Step 1 of 3
Press the theater mode icon to turn the function on or off.
Step 2 of 3
Press the Digital Crown to return to the home screen.
Step 3 of 3
