Google Pixel 11 Pro Fold
Selecting ring tone
You can select the ring tone you want to hear when you get a call.
Press Sound and vibration.
Press Ringtone.
Press the required category.
Press the required ring tones to hear them.
Once you've found a ring tone you like, press Save.
To use a different ring tone than the default ones, press My Sounds and follow the instructions on the screen to select the required ring tone.
