Huawei
P20
Huawei P20
f-9356740a-30c9-4e33-ab68-a3d80a63fe3a
f-953c2f2c-7382-4fe9-8b2e-64c81334178a
f-a634bb91-ebe2-48b9-b67f-e6673d594937
f-c900a922-c7a5-4ae2-aae0-e7dab355f6dd
f-864caf48-1b4e-4b33-876a-dd1264fbbae3
f-b4b058ea-e885-42a8-b933-e968c3948b8c
Can you make a voice call?
