Huawei P20
Solution 3 of 3: Your phone doesn't turn on correctly
Before you can turn on your phone, you need to insert your SIM into your phone.
If you're asked to key in your PIN, do so and press OK. The default PIN is 1111.
Press Power off.
Press Touch to power off.
