iPhone 11 Pro Max
![f-3a7e4ec0-1475-4f61-a930-084fea643e88](http://wmstatic.global.ssl.fastly.net/ml/020724-f-3a7e4ec0-1475-4f61-a930-084fea643e88.png?width=140&height=200)
![f-5a24cf43-c92b-4747-b090-cb49cce6a42d](http://wmstatic.global.ssl.fastly.net/ml/020724-f-5a24cf43-c92b-4747-b090-cb49cce6a42d.png?width=140&height=200)
![f-f13b3424-3ff9-4db3-81c3-18e0f3392f93](http://wmstatic.global.ssl.fastly.net/ml/020724-f-f13b3424-3ff9-4db3-81c3-18e0f3392f93.png?width=140&height=200)
![f-ba1a3150-61a5-4025-8a07-71094920c51f](http://wmstatic.global.ssl.fastly.net/ml/020724-f-ba1a3150-61a5-4025-8a07-71094920c51f.png?width=140&height=200)
![f-ac8ec1e2-754f-462d-b232-5b6f0225cf8f](http://wmstatic.global.ssl.fastly.net/ml/020724-f-ac8ec1e2-754f-462d-b232-5b6f0225cf8f.png?width=140&height=200)
![f-a1614ec3-2011-49e3-9b5e-d8df99f321a8](http://wmstatic.global.ssl.fastly.net/ml/020724-f-a1614ec3-2011-49e3-9b5e-d8df99f321a8.png?width=140&height=200)
You can transfer files, such as pictures or audio files, between your computer and your phone. Please note that the following steps are based on Windows OS which means the instructions do not correspond with other operating systems.
Click iTunes.
Click File.
Click Add File to Library... to add one file at a time.
Click Add Folder to Library... to add a folder.
Go to the required file or folder in your computer's file system and follow the instructions on the screen to add a file or folder to the iTunes library.
Depending on your settings in iTunes, the transfer may start automatically. To manually start the transfer, click the iPhone icon.
Click the required category, and follow the instructions on the screen to select the required settings.
Click Apply.
Go to the required folder in your phone's file system.
