iPhone 12 Pro Max
![f-d742ea13-14e2-474f-8382-3e0e7fe59842](http://wmstatic.global.ssl.fastly.net/ml/120824-f-d742ea13-14e2-474f-8382-3e0e7fe59842.png?width=140&height=200)
![f-0910fa10-f236-401c-9ed0-e129c3bd1bcf](http://wmstatic.global.ssl.fastly.net/ml/120824-f-0910fa10-f236-401c-9ed0-e129c3bd1bcf.png?width=140&height=200)
![f-47efced3-f74f-4ffa-bf14-c5ce5d5e5250](http://wmstatic.global.ssl.fastly.net/ml/120824-f-47efced3-f74f-4ffa-bf14-c5ce5d5e5250.png?width=140&height=200)
![f-578d49fd-d837-4402-b763-2525e7f72184](http://wmstatic.global.ssl.fastly.net/ml/120824-f-578d49fd-d837-4402-b763-2525e7f72184.png?width=140&height=200)
![f-20a530fb-49ae-4254-93f6-7da2dd35b37b](http://wmstatic.global.ssl.fastly.net/ml/120824-f-20a530fb-49ae-4254-93f6-7da2dd35b37b.png?width=140&height=200)
![f-3c8a75dc-d3bf-413d-9a75-8f1944586cba](http://wmstatic.global.ssl.fastly.net/ml/120824-f-3c8a75dc-d3bf-413d-9a75-8f1944586cba.png?width=140&height=200)
![Press Settings. Press Settings.](http://wmstatic.global.ssl.fastly.net/ml/120824-f-911dd421-ecd3-45da-8e75-21031e9b5c90.png?width=238&height=514)
![Press Settings. Press Settings.](http://wmstatic.global.ssl.fastly.net/ml/120824-f-911dd421-ecd3-45da-8e75-21031e9b5c90.png?width=350&height=760)
![Press General. Press General.](http://wmstatic.global.ssl.fastly.net/ml/120824-f-85d16b97-5286-4ac8-a051-16abbd8fa309.png?width=238&height=514)
![Press General. Press General.](http://wmstatic.global.ssl.fastly.net/ml/120824-f-85d16b97-5286-4ac8-a051-16abbd8fa309.png?width=350&height=760)
Press General.
![Press Transfer or Reset iPhone. Press Transfer or Reset iPhone.](http://wmstatic.global.ssl.fastly.net/ml/120824-f-c721ef49-683a-4dc7-9d0f-9118923b826d.png?width=238&height=514)
![Press Transfer or Reset iPhone. Press Transfer or Reset iPhone.](http://wmstatic.global.ssl.fastly.net/ml/120824-f-c721ef49-683a-4dc7-9d0f-9118923b826d.png?width=350&height=760)
![Press Reset. Press Reset.](http://wmstatic.global.ssl.fastly.net/ml/120824-f-1f8b19e8-3e2d-4270-a726-6ca6b45c20e3.png?width=238&height=514)
![Press Reset. Press Reset.](http://wmstatic.global.ssl.fastly.net/ml/120824-f-1f8b19e8-3e2d-4270-a726-6ca6b45c20e3.png?width=350&height=760)
If you choose to restore settings only, all phone settings are restored but contacts, audio files, videos and appointments will not be deleted.
Press Reset.
![Press Reset All Settings. Press Reset All Settings.](http://wmstatic.global.ssl.fastly.net/ml/120824-f-12c558ac-4a18-44d5-9287-f8837719741f.png?width=238&height=514)
![Press Reset All Settings. Press Reset All Settings.](http://wmstatic.global.ssl.fastly.net/ml/120824-f-12c558ac-4a18-44d5-9287-f8837719741f.png?width=350&height=760)
![Press Reset All Settings. Press Reset All Settings.](http://wmstatic.global.ssl.fastly.net/ml/120824-f-19c8e2eb-e186-42e3-a67b-3bba0340189a.png?width=238&height=514)
![Press Reset All Settings. Press Reset All Settings.](http://wmstatic.global.ssl.fastly.net/ml/120824-f-19c8e2eb-e186-42e3-a67b-3bba0340189a.png?width=350&height=760)
![Press Reset All Settings. Wait a moment while the factory default settings are restored. Follow the instructions on the screen to set up your phone and prepare it for use. Press Reset All Settings. Wait a moment while the factory default settings are restored. Follow the instructions on the screen to set up your phone and prepare it for use.](http://wmstatic.global.ssl.fastly.net/ml/120824-f-ccba1f80-32e2-4c6c-a1da-284b3f5ef3a5.png?width=238&height=514)
![Press Reset All Settings. Wait a moment while the factory default settings are restored. Follow the instructions on the screen to set up your phone and prepare it for use. Press Reset All Settings. Wait a moment while the factory default settings are restored. Follow the instructions on the screen to set up your phone and prepare it for use.](http://wmstatic.global.ssl.fastly.net/ml/120824-f-ccba1f80-32e2-4c6c-a1da-284b3f5ef3a5.png?width=350&height=760)
![Press Erase All Content and Settings. Press Erase All Content and Settings.](http://wmstatic.global.ssl.fastly.net/ml/120824-f-1f8b19e8-3e2d-4270-a726-6ca6b45c20e3.png?width=238&height=514)
![Press Erase All Content and Settings. Press Erase All Content and Settings.](http://wmstatic.global.ssl.fastly.net/ml/120824-f-1f8b19e8-3e2d-4270-a726-6ca6b45c20e3.png?width=350&height=760)
If you choose to restore settings and data, settings, contacts, audio files, videos and appointments are deleted. When you've restored settings and data, you need to activate your phone.
![Press Continue. Press Continue.](http://wmstatic.global.ssl.fastly.net/ml/120824-f-dbbb5b23-ee21-46b6-b1b4-95f9034719ea.png?width=238&height=514)
![Press Continue. Press Continue.](http://wmstatic.global.ssl.fastly.net/ml/120824-f-dbbb5b23-ee21-46b6-b1b4-95f9034719ea.png?width=350&height=760)
Press Continue.
![Press the required setting. Press the required setting.](http://wmstatic.global.ssl.fastly.net/ml/120824-f-fe8f3195-619d-494d-83a2-bafd889a9c87.png?width=238&height=514)
![Press the required setting. Press the required setting.](http://wmstatic.global.ssl.fastly.net/ml/120824-f-fe8f3195-619d-494d-83a2-bafd889a9c87.png?width=350&height=760)
![Press Turn Off. Press Turn Off.](http://wmstatic.global.ssl.fastly.net/ml/120824-f-2b2ab37f-e1e3-4633-be87-ce16cdcbe6e9.png?width=238&height=514)
![Press Turn Off. Press Turn Off.](http://wmstatic.global.ssl.fastly.net/ml/120824-f-2b2ab37f-e1e3-4633-be87-ce16cdcbe6e9.png?width=350&height=760)
Press Turn Off.
![Key in the password for your Apple ID and press Erase iPhone. Wait a moment while the factory default settings are restored. Follow the instructions on the screen to set up your phone and prepare it for use. Key in the password for your Apple ID and press Erase iPhone. Wait a moment while the factory default settings are restored. Follow the instructions on the screen to set up your phone and prepare it for use.](http://wmstatic.global.ssl.fastly.net/ml/120824-f-55aa0b1d-edcd-4db6-b3e9-8d126455fcfd.png?width=238&height=514)
![Key in the password for your Apple ID and press Erase iPhone. Wait a moment while the factory default settings are restored. Follow the instructions on the screen to set up your phone and prepare it for use. Key in the password for your Apple ID and press Erase iPhone. Wait a moment while the factory default settings are restored. Follow the instructions on the screen to set up your phone and prepare it for use.](http://wmstatic.global.ssl.fastly.net/ml/120824-f-55aa0b1d-edcd-4db6-b3e9-8d126455fcfd.png?width=350&height=760)
