iPhone 13
![f-2480569d-0263-4cb5-a675-9d105e80713f](http://wmstatic.global.ssl.fastly.net/ml/120824-f-2480569d-0263-4cb5-a675-9d105e80713f.png?width=140&height=200)
![f-b7bce7f0-7433-461f-93c2-b45dc3f3013f](http://wmstatic.global.ssl.fastly.net/ml/120824-f-b7bce7f0-7433-461f-93c2-b45dc3f3013f.png?width=140&height=200)
![f-3ca5983a-5043-4a0f-8975-e19df73f5e88](http://wmstatic.global.ssl.fastly.net/ml/120824-f-3ca5983a-5043-4a0f-8975-e19df73f5e88.png?width=140&height=200)
![f-8007e571-34a2-463d-bb6a-97ab903d986e](http://wmstatic.global.ssl.fastly.net/ml/120824-f-8007e571-34a2-463d-bb6a-97ab903d986e.png?width=140&height=200)
![f-88fe64a5-d033-42b2-a099-c382051a73a0](http://wmstatic.global.ssl.fastly.net/ml/120824-f-88fe64a5-d033-42b2-a099-c382051a73a0.png?width=140&height=200)
![f-e2562d1f-6a13-4370-a45c-0aa0c02904bb](http://wmstatic.global.ssl.fastly.net/ml/120824-f-e2562d1f-6a13-4370-a45c-0aa0c02904bb.png?width=140&height=200)
Selecting FaceTime settings
You can make a video call to another device which supports FaceTime. To select settings for FaceTime, you need to activate your Apple ID on your phone.
![Press Settings. Press Settings.](http://wmstatic.global.ssl.fastly.net/ml/120824-f-df72e3c6-38f3-4fef-91a5-dce1a01dc8aa.png?width=238&height=514)
![Press Settings. Press Settings.](http://wmstatic.global.ssl.fastly.net/ml/120824-f-df72e3c6-38f3-4fef-91a5-dce1a01dc8aa.png?width=354&height=766)
![Press FaceTime. Press FaceTime.](http://wmstatic.global.ssl.fastly.net/ml/120824-f-6b3315f9-5d31-4860-b6ef-033735032871.png?width=238&height=514)
![Press FaceTime. Press FaceTime.](http://wmstatic.global.ssl.fastly.net/ml/120824-f-6b3315f9-5d31-4860-b6ef-033735032871.png?width=354&height=766)
Press FaceTime.
![Press the indicator next to Press the indicator next to](http://wmstatic.global.ssl.fastly.net/ml/120824-f-2fa206cc-ea34-430f-9d16-9bce8ef1cae1.png?width=238&height=514)
![Press the indicator next to Press the indicator next to](http://wmstatic.global.ssl.fastly.net/ml/120824-f-2fa206cc-ea34-430f-9d16-9bce8ef1cae1.png?width=354&height=766)
Press the indicator next to "FaceTime" to turn the function on or off.
![Press the required setting below Press the required setting below](http://wmstatic.global.ssl.fastly.net/ml/120824-f-2fa206cc-ea34-430f-9d16-9bce8ef1cae1.png?width=238&height=514)
![Press the required setting below Press the required setting below](http://wmstatic.global.ssl.fastly.net/ml/120824-f-2fa206cc-ea34-430f-9d16-9bce8ef1cae1.png?width=354&height=766)
Press the required setting below "YOU CAN BE REACHED BY FACETIME AT".
Press the required setting below "CALLER ID".
Press the required setting below "ALLOW FACETIME TO ACCESS" and follow the instructions on the screen to allow access for specific apps and functions.
![Press SharePlay. Press SharePlay.](http://wmstatic.global.ssl.fastly.net/ml/120824-f-a6d7e914-8664-4b47-b290-2085fcf9282a.png?width=238&height=514)
![Press SharePlay. Press SharePlay.](http://wmstatic.global.ssl.fastly.net/ml/120824-f-a6d7e914-8664-4b47-b290-2085fcf9282a.png?width=354&height=766)
Press SharePlay.
![Press the indicator next to Press the indicator next to](http://wmstatic.global.ssl.fastly.net/ml/120824-f-d6959844-0da9-4692-84a6-8ab4463ac81d.png?width=238&height=514)
![Press the indicator next to Press the indicator next to](http://wmstatic.global.ssl.fastly.net/ml/120824-f-d6959844-0da9-4692-84a6-8ab4463ac81d.png?width=354&height=766)
Press the indicator next to "SharePlay" to turn the function on or off.
![Press arrow left. Press arrow left.](http://wmstatic.global.ssl.fastly.net/ml/120824-f-d6959844-0da9-4692-84a6-8ab4463ac81d.png?width=238&height=514)
![Press arrow left. Press arrow left.](http://wmstatic.global.ssl.fastly.net/ml/120824-f-d6959844-0da9-4692-84a6-8ab4463ac81d.png?width=354&height=766)
Press arrow left.
![Press the indicator next to Press the indicator next to](http://wmstatic.global.ssl.fastly.net/ml/120824-f-a6d7e914-8664-4b47-b290-2085fcf9282a.png?width=238&height=514)
![Press the indicator next to Press the indicator next to](http://wmstatic.global.ssl.fastly.net/ml/120824-f-a6d7e914-8664-4b47-b290-2085fcf9282a.png?width=354&height=766)
Press the indicator next to "Speaking" to turn the function on or off.
Press the indicator next to "FaceTime Live Photos" to turn the function on or off.
Press the indicator next to "Eye Contact" to turn the function on or off.
![Press Blocked Contacts. Press Blocked Contacts.](http://wmstatic.global.ssl.fastly.net/ml/120824-f-a6d7e914-8664-4b47-b290-2085fcf9282a.png?width=238&height=514)
![Press Blocked Contacts. Press Blocked Contacts.](http://wmstatic.global.ssl.fastly.net/ml/120824-f-a6d7e914-8664-4b47-b290-2085fcf9282a.png?width=354&height=766)
![Press Add New... and follow the instructions on the screen to block a contact. Press Add New... and follow the instructions on the screen to block a contact.](http://wmstatic.global.ssl.fastly.net/ml/120824-f-988cef40-224d-44be-8750-5c5542b8ab4f.png?width=238&height=514)
![Press Add New... and follow the instructions on the screen to block a contact. Press Add New... and follow the instructions on the screen to block a contact.](http://wmstatic.global.ssl.fastly.net/ml/120824-f-988cef40-224d-44be-8750-5c5542b8ab4f.png?width=354&height=766)
![Press arrow left. Press arrow left.](http://wmstatic.global.ssl.fastly.net/ml/120824-f-988cef40-224d-44be-8750-5c5542b8ab4f.png?width=238&height=514)
![Press arrow left. Press arrow left.](http://wmstatic.global.ssl.fastly.net/ml/120824-f-988cef40-224d-44be-8750-5c5542b8ab4f.png?width=354&height=766)
Press arrow left.
![Press Silence Unknown Callers. Press Silence Unknown Callers.](http://wmstatic.global.ssl.fastly.net/ml/120824-f-a6d7e914-8664-4b47-b290-2085fcf9282a.png?width=238&height=514)
![Press Silence Unknown Callers. Press Silence Unknown Callers.](http://wmstatic.global.ssl.fastly.net/ml/120824-f-a6d7e914-8664-4b47-b290-2085fcf9282a.png?width=354&height=766)
![Press the indicator next to Press the indicator next to](http://wmstatic.global.ssl.fastly.net/ml/120824-f-b70f8e75-4cc9-466d-bf15-1097bd1d8246.png?width=238&height=514)
![Press the indicator next to Press the indicator next to](http://wmstatic.global.ssl.fastly.net/ml/120824-f-b70f8e75-4cc9-466d-bf15-1097bd1d8246.png?width=354&height=766)
Press the indicator next to "Silence Unknown Callers" to turn the function on or off.
![Slide your finger upwards starting from the bottom of the screen to return to the home screen. Slide your finger upwards starting from the bottom of the screen to return to the home screen.](http://wmstatic.global.ssl.fastly.net/ml/120824-f-b70f8e75-4cc9-466d-bf15-1097bd1d8246.png?width=238&height=514)
![Slide your finger upwards starting from the bottom of the screen to return to the home screen. Slide your finger upwards starting from the bottom of the screen to return to the home screen.](http://wmstatic.global.ssl.fastly.net/ml/120824-f-b70f8e75-4cc9-466d-bf15-1097bd1d8246.png?width=354&height=766)
