iPhone 16 Pro Max
iPhone 16 Pro Max
f-4e9b6905-6707-4dee-bfec-c993e12cfb6e
f-4a8a5595-783b-4e0e-8467-d2d5e9fc4016
f-388ab6ae-eae7-4ecc-8984-b40574146c13
f-a3ca6912-9c27-4750-ad0e-6d2b17b1d94b
f-f1ab022a-d37e-47a9-85ba-49e9e77fcbc8
f-39a9b493-0785-4d9a-9273-0cebbabc19f7
f-aaf55971-cf99-4796-b86c-19cddc9f018a
f-e8815344-f66c-445a-9932-f831589ad59e
Solution 2 of 7: Automatic mobile data usage is turned on
You can set your phone to use mobile data automatically when the connection to the Wi-Fi network is weak. To turn Wi-Fi Assist on or off, you need to turn on mobile data.
Step 1 of 4
Press Wi-Fi.
Press Wi-Fi.
Step 2 of 4
Press Wi-Fi.
Step 3 of 4
Press the indicator next to "Connectivity Assist" to turn the function on or off.
Step 4 of 4
