iPhone 18 Pro Max
iPhone 18 Pro Max
f-fc865c10-0256-4bcf-b117-2245fec39123
f-98e414ec-4119-4010-84a9-d03d974c8274
f-00a60af5-a8a8-4293-8f08-301d87a2419c
f-fc0e9bb7-1ae2-4db9-a228-dc564e1f38ca
f-348f0be3-3d20-4d45-8dec-1c654670e506
f-3bc0156b-328c-4aa2-a141-b256ed4229f5
f-dfc9aa71-bba7-4680-9bbe-c8ea4bd7b1de
f-a890513d-6f6b-4343-9878-15ea66057110
Using widgets
You can use widgets on your phone allowing you to get a quick overview of selected apps. You can choose between different widget sizes, organise widgets in stacks and place them on the home screen.
Slide your finger right on the screen to open the widget menu.
Step 1 of 33
Slide your finger up or down on the screen to see more widgets.
Step 2 of 33
Press and hold anywhere on the screen.
Step 3 of 33
Press the edit icon.
Step 4 of 33
Press Add Widget.
Press Add Widget.
Step 5 of 33
Press Add Widget.
Press the required widget.
Step 6 of 33
If the required widget is not displayed on the list, press the search field and follow the instructions on the screen to find the required widget.
Step 7 of 33
Slide your finger right or left on the screen to select the required widget size.
Step 8 of 33
Press Add Widget.
Press Add Widget.
Step 9 of 33
Press Add Widget.
Press the confirm icon.
Step 10 of 33
Step 11 of 33
A Smart Stack is an automatically created selection of widgets.
Step 12 of 33
Press Add Widget.
Press Add Widget.
Step 13 of 33
Press Add Widget.
Press Smart Stack.
Press Smart Stack.
Step 14 of 33
Press Smart Stack.
Step 15 of 33
Press Add Widget.
Press Add Widget.
Step 16 of 33
Press Add Widget.
Step 17 of 33
Press the required widget and drag it on top of another widget.
Step 18 of 33
You can manually organise the required widgets in stacks. Please note that you can only create stacks containing widgets of the same size.
Step 19 of 33
Press and hold the required Widget Stack.
Step 20 of 33
Press Edit Stack.
Press Edit Stack.
Step 21 of 33
Press Edit Stack.
Press Smart Rotate to turn the function on or off.
Step 22 of 33
Your phone can control which widgets to display based on factors such as time, GPS position or your activity.
Press and drag the required widget to the required location.
Step 23 of 33
You can change the display order of widgets when using a Widget Stack.
Press the delete icon on the required widget to remove it from the stack.
Step 24 of 33
Step 25 of 33
Press and hold the required widget until a pop-up menu is displayed.
Step 26 of 33
Press Remove Widget.
Step 27 of 33
Press Remove.
Press Remove.
Step 28 of 33
Press Remove.
Press and hold the required widget. Drag the selected widget to the required position on the home screen.
Step 29 of 33
Step 30 of 33
If you're using a Widget Stack: slide up or down on the stack to select the required widget.
Step 31 of 33
Press the required widget to open the app.
Step 32 of 33
Step 33 of 33
