iPhone 18 Pro Max
iPhone 18 Pro Max
f-fc865c10-0256-4bcf-b117-2245fec39123
f-98e414ec-4119-4010-84a9-d03d974c8274
f-00a60af5-a8a8-4293-8f08-301d87a2419c
f-fc0e9bb7-1ae2-4db9-a228-dc564e1f38ca
f-348f0be3-3d20-4d45-8dec-1c654670e506
f-3bc0156b-328c-4aa2-a141-b256ed4229f5
f-dfc9aa71-bba7-4680-9bbe-c8ea4bd7b1de
f-a890513d-6f6b-4343-9878-15ea66057110
I can't send and receive iMessages
If you can't send and receive iMessages, there may be several causes of the problem.
It's important to find out if you can make a call. If you can't make a call, you need to solve this problem first. When the problem is solved, you will most likely also be able to send and receive iMessages.
Can you make a voice call?
