iPhone 18 Pro Max
iPhone 18 Pro Max
f-fc865c10-0256-4bcf-b117-2245fec39123
f-98e414ec-4119-4010-84a9-d03d974c8274
f-00a60af5-a8a8-4293-8f08-301d87a2419c
f-fc0e9bb7-1ae2-4db9-a228-dc564e1f38ca
f-348f0be3-3d20-4d45-8dec-1c654670e506
f-3bc0156b-328c-4aa2-a141-b256ed4229f5
f-dfc9aa71-bba7-4680-9bbe-c8ea4bd7b1de
f-a890513d-6f6b-4343-9878-15ea66057110
Selecting settings for Siri AI
You can use Siri AI to answer your questions in an informative way, perform tasks and interact with apps on your phone. To use Siri AI, you need to activate your Apple Account on your phone.
Step 1 of 17
Press Siri.
Press Siri.
Step 2 of 17
Press Siri.
If it's the first time you use Siri AI, press Turn On Siri.
Step 3 of 17
Press Try Siri AI and follow the instructions on the screen to turn on the function.
Step 4 of 17
Press Requests.
Press Requests.
Step 5 of 17
Press Requests.
Press the required setting to turn the function on or off. If you turn on the function, you need to follow the instructions on the screen to set up Siri to recognise your voice.
Step 6 of 17
Step 7 of 17
Press the indicator next to "Press Side Button for Siri" to turn activation using the Side button on or off.
Press arrow left.
Press arrow left.
Step 8 of 17
Press arrow left.
Press Language and follow the instructions on the screen to select the required language.
Step 9 of 17
Press Voice and follow the instructions on the screen to select the required accent and voice.
Step 10 of 17
Press Responses and follow the instructions on the screen to select the required settings.
Step 11 of 17
Press Your Information.
Step 12 of 17
Press the required contact.
Step 13 of 17
When you select yourself as the owner of the phone, your phone uses your information for different voice control functions such as navigation to your home address. Before you can select yourself as the owner of the phone, you need to create yourself as a contact in the address book.
Press the required category below
Step 14 of 17
Press the required category below "Siri App" and follow the instructions on the screen to select the required settings.
You can select different settings for the Siri AI app, e.g., for viewing and storing conversations.
Press ChatGPT and follow the instructions on the screen to turn use of ChatGPT on or off.
Step 15 of 17
Follow the instructions on the screen to select more settings for Siri AI.
Step 16 of 17
You can select more settings for Siri AI, e.g., automatic identification of objects and information retrieval from pictures, as well as receiving suggestions for actions across different apps.
Step 17 of 17
